Derby Torx Screw Replacement
According to the Harley P&A catalog, looks like Harley does offer a grade 8 in chrome, not so sure about zink screws, though indyfjr mentioned they did.
I'm a little surprised by some of the replies; I had thought changing them out was a good idea to resolve a 'known issue'. But it looks like it isn't the problem issue that I thought it was. Maybe I read a thread regarding changing out from Torx to hex on some other part. Reading so many threads, all the information gets mixed up in my head, I guess. Man, wait until I'm older... I won't be able to remember anything. Oops, I already am.
Received 2,524 Likes
Hex feels to me like it sits deeper in the bolt, so sure, maybe less area, but I never felt about hex bolts the way I do about torx.
I've never had an issue with the Torx, but thought it was a common complaint here that it's easy to strip the head and that many suggest changing them out to the hex. I just want to be proactive in preventing a problem down the road since that's the kind of luck I usually have when I put a tool in my hand.
Some say give it a tap with a hammer then back it out.
I use a 1/4 inch impact gun with T-27 and give short bursts in reverse.
Ragtop wrote above:
[[ I would take one out, and bring it to your local ACE hardware store.
The store near me has a good assortment of chrome, Allen head, Torx, etc.
Not exactly cheap, but probably less than the HD dealer! ]]
I second Ragtop's recommendations.
Don't get TORX -- get allen head bolts instead.
I replaced the TORX bolts with stainless allen heads from the local hardware store.
IMPORTANT:
While you're there, get some anti-seize lubricant as well (Permatex, etc.).
Coat the threads with anti-seize before you put them in.
DON'T use a torque wrench, or even a standard ratchet wrench on these. A plain ol' L-shaped allen wrench will do. Get it snug, and then a little more. When you use an L-wrench you won't over-torque it or strip the threads.
Some years back Sears used to sell a small palm-sized ratchet that was good for smaller bolts like this. Not sure if they can still be found.
IMPORTANT:
Reading this I'm reliving my first nightmare with the TORX screws. Shonuff, I used the 25 instead of the 27, and one of those buggers stripped. I 'bout peed my pants when I realized I had to drill the head off to remove the derby (I had already drained the primary fluid). All turned out well though, and shortly thereafter I went and bought the service manual.
