Breather /Crank case venting
#31
Received 3,940 Likes
Honestly, I think the DK Customs kit is probably the best bang for your buck. The breather bolts are nicely chromed and look pretty good. Two things about it that you might change. The "T" that comes with the kit is plastic. I went to Autozone and bought a brass T. The hose that comes with the kit is just black rubber "oil line" hose. I had no problem with that, but I don't have a CVO. You might want to use some nice braided line. If you do a search, you'll find that some guys really went all out. But I wanted something that would install "out of the box" and with the exception of the T, that's what I got from DK Custom's kit.
David
David
With the filter on the end of the hose, you do not get drips on the ground when you park, and you do not get spray on the bike or rider/passenger while riding. The filters we use will absorb the carry-over oil (blow-by) on a typical HD for 5,000 or more miles of riding.
If you wash your ride at least every 5,000 miles, then just spray a little soap on the filter (you don't need to remove it), let it set, then spray it off after a few minutes and the absorbed oil is cleaned out of the filter and it is ready to absorb more.
Catch Cans are definitely cool...and we have played with the idea for years of making some systems with catch cans. The reason we have not...there are so many different designs/looks, that even if we came out with a few, there would be 10 more cool looks that we didn't do...and the bottom line...it costs more and is no more effective than having a filter at the end of the hose.
#32
....With that air cleaner, you can use our Discrete System. You will need to drill and tap two holes, and thread fittings into them.....
You know, if you put together a kit that included the fittings, and directions on how to tap them, I would definitely purchase one, along with the Discreet System and external breather. I have the same 110 air cleaner as the OP.
Just a thought.....
#33
We appreciate your interest in our products. Depending on what air cleaner you have, depends on which breather system will work best for your setup.
If your support bracket is no more than 1/4" thick, then our premium discrete breather system will work.
Below is a link to that product.
CLICK ME
Here is a picture with the braided line on our Air Cleaner:
CLICK ME
#34
You can send an email to the contact information below, and I can send you a copy of the Instructions, this way you can look at them before hand and we can help you with any questions you may have.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
#35
Just to be clear,Teflon sealant or Teflon tape or do you think it matters?
#36
Yes, we might do that. Thank you.
Either will work. Sealant is a bit easier to use, but tape is not so messy when removing.
#37
OK, so I installed the 1/8 NPT to barb fittings to my backing plate. I am going to install a T so that I can vent to a crankcase breather filter with a 3/8" nipple. Should I use 3/8 i.d. hose for all connections; or, can I use 1/4" from the NPT fittings and then go to 3/8 from the T to the filter?
What have you folks been doing?
#38
#40
High temp 1/4" ID(inside diameter). Got it here.
http://www.ebay.com/itm/190811667279...%3AMEBIDX%3AIT
