07 Ultra rear brake switch
Riding last Sunday friends noticed brake light not working correctly. After I got it home found that foot brake had no brake lights. Figure that's the switch, but would it cause the cruise to not disengage with footbrake pedal too?? Also when changing the switch is it necessary to drain brake fluid?? Front hand brake still has brake lights and disengages cruise control. Any help greatly appreciated.
Thanks Scott
Thanks Scott
Thanks Scott
Thanks Scott
as stated above, no you do not need to drain the fluid or bleed your brakes. simply have the new switch in hand when you pull the old one off and immediately screw it back in the socket.
Every time I replace a inline brake component I always bleed the brake system afterwards. Any time you break open a closed system air is introduced in to the system. So. I recommend bleeding the brake system after replacement of the brake light switch. It does not take long and you are assured your brakes are operating at optimum performance. Which you may be thankful for.
JCBGlide
2014-2023 Touring Models
07-01-2018 04:21 PM
