07 Road King not starting
tried to start my bike, well it tried to start but would not turn over. I put it back on charge for a bit. Tried again and it went CLICK, CLICK, ETC... I check the fuses, grounds, battery good. Just getting the clicking sound. Is the starter gone or could it be the stator? The pump still sounds good when you turn it on and all the lights come on.
07 King,EFI, V&H all the way.
How old is your battery? Sounds like it's on it's way out. Did it crank hard and not start before draining? If so it's probably not the battery. Put a jump on the battery and crank it hard to see if it will start. If so, it's a weak battery. Also be sure to check your charging system when you get it started esp. the voltage regulator. Instructions are on here on how to do that. Good luck.
