Is a backrest worth it?
#31
I finally installed the HD adjustable backrest on my Tri Glide. I really like it but initially had one problem.
The vertical adjustment on it was a sloppy fit. Wiggled all over when leaning back against it. Very annoying.
I selected the correct height for me and welded it solid. Removed the spring-loaded button and other stuff associated with that vertical adjustment.
I still have the fore-aft adjustment.
Now when leaning back it is very solid. No longer feel the pain from slouching.
#32
Received 3,941 Likes
A backrest with some adjustment can make a huge difference in comfort. Also, if you get one that has a little pocket on the back of it, your passenger will really thank you for it!
I've had one on my last 6 baggers.
#34
So I modified it today. There is about 2 inches between the bottom of the pad at the lowest position and the top of the seat. I cut the steel bar at the half-way point between the bottom of the pad adjuster and the bend and overlapped the two parts. The overlap is about 2 inches, thus eliminating the excess height. Then I drilled two holes and assembled them with two 1/4 bolts. I assembled it with the top part bolted to the back side of the bottom part, thus moving it back just a little.
the backrest support cut, overlapped, and bolted back together.
On the bike at the lowest position, the backrest now supports my lower back.
The backrest feels just right now. To the OP: yes, get the adjustable backrest. It makes a big difference on longer rides.
#35
#37
#38
#40
