Street Glide Headlamp Trim Ring
OK...what's the trick?
I had to remove the stock headlamp trim ring. Now, I can't for the life of me get the little spring hook into the slot in the mounting plate.
Even if I remove the spring from the ring, hook it through the slot, I can't then get the spring reinserted properly into the ring.
I can hook the spring behind the headlamp shell, and it should be OK. But I want to know the trick to get that dang thing into the slot!
YodaddyKeith
10-23-2019 02:55 PM
