CB SWR Meter Question
Question for you radio guys
I'm going to buy an SWR Meter to tune my CB antenna.
Off these two, which is the one I want?
http://www.meterexpert.com/e/SWT_meter_05.htm
Is one for CB and one for HAM? They test different frequencies, I'm confused?
Thanks
Thanks
Thanks
Thanks
The "RS-27" The frequency range for CB is: 26.9650 MHz to 27.4050 MHz ...
I have a 2014 FLHTK SE. I was planning to change my coax from the radio all the way to the antenna. I purchased 18 feet of 97% shielded coax. My question for someone that tried this is it possible to cut the stock coax at one end and attach the new coax to it and pull it through or is it fastened to tight to try this. I feel the new coax properly installed should eliminate some of the noise and will make using the swr meter a little easier. Thanks Ben
Ben,
I would just pull the tank to get at the wire loom channel, not that hard on a 2014.
Lots of the wires in the loom are zip tied together.
