Tman cam help 600SM vs 577
Trying to figure out which cam is going to be the best in my bike. I have a 2012 RGU with a Pro Race Stage 4 103. Heads, 259 cam, larger injectors, 58 mm throttle body, and most importantly 10.5-1 pistons. Here are the specs on both cams:
600 SM
Open Close Lift Duration Centerline TDC LSA Overlap
Intake 21 39 600 240 99 198 100.5 40
Exhaust 43 19 600 242 102 183
577
Intake 20 46 577 246 103 196 104.5 38
Exhaust 50 18 577 248 106 171
I want a cam that comes in at around 2500 rpm and pulls to 6200 rpm. The Harley 259 cam sucks. Here are the 259 specs:
Intake 19 47 579 246 182
Exhaust 58 12 579 250 155
600 SM
577
I talked to TMan this afternoon actually. They recommended the new 577 cam. It seems to like the higher compression more than the 600SM. I guess thats the one I'll go with. It's a midrange upper end cam that is streetable. It has great low end torque as well with my setup.
He said it should solve my power issues. My bike was dyno'd at 106/106 when it was tuned. Kinda low for all the upgrades.
If you look on Tman's facebook page this cam pulls these 100/110 numbers with a stock engine, tuner, and exhaust. All I could say is wow when I talked to him.
I had the HD 255 cam in my previous bike and it pulled like a freight train. I can only imagine how well the 625s pull.
