Rotors….Which Ones?
I stand corrected on the ten button design of EBC rotor, that is for the rear wheel only, the fronts are five spoke as per hd_rolling's photo.
As for composite brakes, the Lyndall ones are designed for street race, AFAIK and I have seen plenty of favourable reviews by members who use them. I don't believe they qualify as being 'carbon', in the same way as race brakes are. I would be happy to buy them, if they had stock!
Yes I have seen Lyndall's advertising claims and I have seem some reviews stating that after spending 2 thousand dollars on 3 brake rotors and 3 sets of brake pads some people are happy. But I'd have to ride em first. They are called Carbon Metal Matrix, so I would suspect they do need warm up to work properly, but thats why I would need a ride on a bike to experience it for myself before plunking down 2k for some brake rotors
The web store is confusing. So I could see how you would think the price is lower. Add the rotors to your online cart and see, they are $499 apiece, not 3 for 998. Its 1 for 499 and +998 for the other 2 . I just did it and the cost for 3 rotors plus 3 sets of pads is almost $1700 before tax and shipping.
Ok i go along with that. Just looked up what MMC rotors are. Aluminum/Magnesium alloy infused with silicon carbide. Should work good at dissipating heat . And the lightness should be a benefit. I'm wondering where the possible braking performance is coming from, is it due to the organic pads needed or is there an increase in friction co efficient when using the rotors along with the pads, or is it just due to the lighter spinning mass, or due to the increased heat convection to the wheels that allows more heat generated by pads to NOT degrade the braking by overheating. Remember these rotors are the same size as oem and the pads are the same size as oem and the calipers and m/c have not been changed in any way. So where is the increase in performance(if any) coming from? I can maybe see the increased heat convection being a possible benefit to the braking if and when a guy really uses his brakes. I still have my concerns of spending nearly 2k on these items, heck they may work better but as I stated I'd need to need to ride em before plunking down that kinda cash. Glad you are pleased.
A lesser improvement is the floating rotors track straighter in the calipers so the pads aren't moving back and forth (tiny amounts) like solid rotors.
Thanks...
