Fish Tail Pipes
The baffled pipes you mention would work just fine, but will never sound like straight fishys. If you want a cheap set of baffles to put in the ebay straight pipe fishtails, these would work just fine.
http://www.ebay.com/itm/2-X-4-DRAG-P...b28d37&vxp=mtr
[QUOTE=bikerlaw;13231216]The baffled pipes you mention would work just fine, but will never sound like straight fishys. If you want a cheap set of baffles to put in the ebay straight pipe fishtails, these would work just fine.
I searched ebay for something like that with no luck- as i do want the open fishtails
So hate to ask , were in pipe do you place these ?? @ tail ? Middle ? Front were pipe mounts to head pipe ?
I really appreciate your help with all the ebay info along with sound clips
Fishtails are definitely "old school". On the right bike they can look good. If you are running fishtails then you almost have to have a pair of "whips" on the handlebar tips too. When I think of fishtail exhausts I immediately think of the old pastel blue bikes of the 50's which came with "gankster walls" and "whips".
[QUOTE=mayhemmaster;13231954]
The baffles will be installed at the open end so that you can drill a hole and hold the screw in place from the open end.
You can find baffles anywhere online....I used the 4" and 8" versions of those listed but went with the fiberglass wrapped ones....again.....search online......might take some experiments to get the sound you want.......all are different......good luck!
[QUOTE=MURPHCC1;13232340]
Thanks Again, Going to stop in local Indy and pick his brain too
Also see what he has in used pipes
