Do most have set to enable or disable ? And what was reason for choice. mine came with disable and not sure what logic to use in deciding. Could build case either way so maybe that's my answer.
Safetyman,Is that 280 degrees F.? Anyway,I always leave mine enabled,even though I run a tuner to enrichen the cyls for cooler running,it still comes on in this South Florida heat at long traffic lights in the summer.
jcapps,Ya I know why they put it there do you??? Think maybe could have something to do with lean tune catalytic converter and un needed heat . And my thinking is with head pipe and proper tune maybe I don't need the extra abuse of bike going into that mode.
That's what is cool about it, pretty easy to enable/disable.. During the summer here in Georgia I leave it enabled. It comes on a lot as most our days are way over 80 degrees. I notice it at idle but it's not a bad feeling or too much vibration for me. I have never had the bike stumble upon take off, blip the throttle and I'm ready to go. Try it yourself and see which way you like it. I'll probably disable soon due to cooler weather coming.
Mine is always enabled. Never had a hesitation problem. Let the computer decide when it is getting too hot. Even if my bike was catless and super tuned I'd have it enabled. It may never activate but it is available.
This was designed for engine heat management to prevent engine overheating. Rider comfort is an ancillary bennefit that is highlighted in their liturature as a marketing tool.
No, he is referring to the ambient air temps, if the temperature is 80 or more then it will engage.
I leave mine turned off. I really don't notice any heat and I don't like the sound when it's active.
