Help with fuel gauge
I had to remove my tank in in order to run some speaker wires.
Today, I finally got a chance to ride. After about 30 miles , I noticed that the gauge was still on F. When I got home, the gauge was still on F. Looking into the tank , it seems like I have about half a tank of fuel left.
I was wondering:
1- could it be a blown 15 amp fuel fuse?
2- could it be one of the harnesses in the dash not plugged in properly?
I pulled off the fairing and checked the connection to the fuel gauge and that's not a problem.
I didn't see anything in the troubleshooting section of the service manual.
Guys please help me figure this out.
Thank you
I was wondering:
Thank you
pull your dash for a do-over.
year and model would help but on the 09 a 4 pin connector is used for the gauge and the fuel pump- the yel/wht wire is for the sender and the blk/grn is the sender ground. orn/gy and black are for the pump.
if the fuse is blowed, none of your other instruments will work
mike
mike
mike
mike
My bike is a 2005 Electra Glide. After about a year the fuel gauge became erratic and eventually just sat on "full." Or was it "empty?" Regardless, after many attempts at trouble-shooting and repairing I gave up and took the gauge out of the fairing. In its stead I re-installed the air temp gauge that I had removed years ago when I put in an oil temp gauge. I put the air temp gauge back primarily to fill the hole, but as everyone knows...without the air temp gauge a person can't tell if they are cold or hot when I'm riding. (A little sarcasm there.)
Now I watch the odometer/tripometer to determine when I need fuel.
FWIW, I used the Service Manual and many on-line articles to trouble shoot the system from the float in the tank to the gauge itself. Every single aspect of the system functions within normal parameters, but the dang needle still sat on empty/full. Obviously the bike is haunted, so why fight it?
If I went by my gauge to determine where my fuel was I'd be filling up 2x more often than I do. Once I've got good documentation of my MPG, I use the trip mileage. When I used to go by my gauge I would fill at approx 140-150 mi point, now I just do the math and go till I'm at 180-190 mi and at times even 200 mi. I always have approx 1 gallon left in the tank.
