Feuling 7060 oil pump and 8015 cam
Old 02-18-2015, 06:58 PM
WhiteGoldSG's Avatar
WhiteGoldSG
WhiteGoldSG is offline
Default Feuling 7060 oil pump and 8015 cam plate. Brand new
both pump and plate are brand new warranty replacements directly from fueling. They warrantied the units I was running due to a pinched O ring which caused scoring on the pump and plate. They sent me BRAND NEW units, but they are stamped with a star to show that they were already warrantied. Wasn't sure if they were gonna warranty, so I picked up a new setup in the time being and now have these for sale. MSRP on the setup is $750. Will sell for $625 shipped
Pm with interest or text 201.207.3505
Below is from fueling website
PUMP PRODUCT DETAILS :
• Billet 6061 aluminum -High Volume oil pump
• Increases oil pressure -Cooler oil & engine temperatures
• No more oily air cleaners -32% more pressure volume than stock,16%+more than SE
• Eliminates blow by & wet sumping -38% more scavenge (return) volume than stock,9%+ more than SE
• More HP and Torque to the rear wheel - Stock replacement
• High Flow 2 Chrome Moly gerotor gears - Feuling[emoji768] design, tolerances & material
• Made in the U.S.A.
Part # 7060 Fits: Twin Cam[emoji768] 07-12 Includes 06 Dyna models $399.95
Fits: Screamin Eagle[emoji768] and other aftermarket camplates which utilize the late style 07-12 oil pumps
FITS :
TC 07- 14, Includes 06 Dyna models, High volume HP+ oil pump, 20%+ more pressure and 30%+ more return volume, 6061 billet aluminum with natural finish
CAM PLATE PRODUCT DETAILS :
• FEULING[emoji768] HIGH FLOW camplates for TC[emoji768] engines increase engine oil flow and volume by enlarging the oil pump reservoirs and critical oil passages including matching the oil port holes throughout the camplate to the port holes in the engine case increasing engine oil flow to the lifters, piston cooling jets, crankshaft and rod bearings resulting in 25-35 degree cooler engine temperatures.
• Made from 7075 billet aluminum which 50% harder and stronger than the factory, SE[emoji768] and other aftermarket camplates. The 7075 increases the strength and hardness of the camplate, holding tighter tolerances under temperature eliminating flexing and the need for bronze bushings as 7075 material has excellent bearing like properties.
• FEULING[emoji768] camplates are blue printed and matched to the Feuling[emoji768] oil pumps, which allow the Twin Cam[emoji768] engine to take full advantage of the increased volume from the high flow oil pumps resulting in cooler quieter engine operation.
• Tighter cam bearing bore tolerance for improved press fit
• Camplates are pressure tested & pressure relief valve and spring are pre-set and designed for the increased volume and pressure, eliminating the need to stretch the spring or use a shim.
• When matched with the Feuling[emoji768] Race Series Oil Pump rear wheel power gains of 3 Horsepower and 4 ft/lbs of Torque are achieved.
• For use ONLY with the Feuling[emoji768] oil pumps
• Bolts into stock location
Part # 8015¹ CAMPLATE TC[emoji768] 07-12 Includes 06 Dyna models. Chain and Gear Drive For use ONLY with FEULING[emoji768] oil pumps #7060 & 7062
• Tighter cam journal bore tolerance for improved cam fitment
• Added Cam journal oil groove for cold start up protection and increased cam journal lubrication
Added oil pressure feed holes to front and back of cam journals to prevent excessive thrusting wear
¹ Gear drive cam systems require block off plates - see Feuling #8016
FITS :
TC, 07 - 14 Includes 06 Dyna, Requires FEULING oil pump #7060 or #7062, Fits both chain drive or gear drive camshafts, Billet 7075, drops engine temps 20-35 degrees cooler than Screamin Eagle or other aftermarket camplates
Sent from my iPad using Tapatalk
Old 02-18-2015, 07:00 PM
WhiteGoldSG
ALL NEW ORINGS INCLUDED
Old 02-23-2015, 05:50 PM
WhiteGoldSG
$570 shipped
Old 02-23-2015, 08:23 PM
ridedaddy's Avatar
ridedaddy
ridedaddy is offline
nice parts for sure, wish I had the extra money while doing my cams.
Old 02-24-2015, 12:09 AM
WhiteGoldSG
Make a REASONABLE offer. Changing things up and dont need these siting on my bench. All i can say is no. If ur gonna do it, do it once.. Do it right!!!
Old 02-25-2015, 08:19 PM
WhiteGoldSG
Sold sold sold
WhiteGoldSG
03-11-2015 03:36 PM
WhiteGoldSG
Touring Parts
03-11-2015 03:36 PM
Pops98
02-01-2015 05:05 PM
BenRK05
03-13-2014 06:06 PM
DMetcalf
03-21-2013 04:51 PM
Quick Reply: Feuling 7060 oil pump and 8015 cam
