Power Commander V - w/Map Relay
For Sale for $200 + Shipping from ZIP Code 89156
I recently upgraded to a Power Vision and I am offering my old PC-V tuner for sale. It was bought from FuelMoto on 8/31/2010 who will provide upgraded maps if necessary. Includes original packaging, CD, Stickers, blank warranty card and USB Cable.
Fuel Moto Description from their website:
Included is my Map Relay Switch so that you can flip between MAP1 and MAP2 on the fly. The switch was made to function off of the ACC Switch on the dash. No wiring necessary. Just plug into the connector under your seat and thats it! Green light on the ACC switch means you are running MAP1, if the green light is off you are running MAP2. The switch was wired to run MAP1 incase of a relay failure. It's all Plug-n-Play!
The maps that are pre-programmed on the PC-V are as follows.
MAP1 :
HD Heavy Breather (Short Element)
FuelMoto StreetGlide Jackpot 2-1-2 Headpipe
FuelMoto Jackpot Dyno Tuned Mufflers
Map2:
Same as above just a bit richer in an attempt to help the cool the engine for the hot Las Vegas summers.
The Power Commander V uses RPM and throttle position inputs to base fuel adjustments on. In some cases additional inputs can be used such as cylinder head or water temperature as well as gear position or boost. The Power Commander V has 250RPM resolution and 10 throttle position columns giving you up to 640 individual mapping points for fuel and an equal number for ignition timing (if ignition equipped). This is the kind of "'point specific" adjustability that is necessary with today's bikes and the parts that are available for them.
The Power Commander V gives you the adjustments you need at an affordable price, with the ease of use today's customers demand.
Fuel and timing control
Allows +/-20 degrees of timing adjustment
Adjust fuel/timing per cylinder
Adjust fuel/timing per gear
Raise your rev limit (only available on select models)
Adjust fuel/timing based on temperature or boost inputs
Software will display J1850 data from bike's stock ECU (this is data such as temp, fuel pulse width, timing advance, spark knock, etc)
Rev Xtend
Individual Cylinder mapping
Reduced size (less than half the size of the PC III USB)
USB Powered from computer (9 volt adapter is no longer needed for programming)
Rev Xtend
MAP1 :
Map2:
dohadex
03-22-2011 05:01 PM
TheBurninator
06-29-2010 01:55 PM
