Bassani Power Curve True-Dual Crossover Header Pipes - FLH211*New in the box*
Bassani Power Curve True-Dual Crossover Header Pipes - FLH211*New in the box*.
Fit 97 - 06 FL
Made from 16-gauge steel, finished in show-quality chrome and supplied with three custom-fit heat shields (reuse two existing heat shields)
Direct bolt-on replacement for stock headpipes
Feature proper port angle and patented matched-length rear headpipe design that produces even performance from each cylinder
Offer improved low-end torque, appearance and an unmistakable exhaust tone
Crossover systems accept any 95-up OEM-style mufflers.
$400.00 plus shipping
Fit 97 - 06 FL
Looking close at the pictures, I would say you should be able to check the trans fluid if you have a 5 speed. 6 speed looks like you may have to remove the header.
