triglide
Thanks to all for response but I know all that have done everything you guys and gals have,I have the problem of not kicking the breaker but all I get is a click out of the solenoid by the main breaker I have a 2012 tri,I was going to buy the tester the manual calls out to trouble shoot it but can't locate one anymore help would be grateful.
I see you are NEW so ..... Just in case. Push the red button to trip the circuit. Push the black lever back into position until it clicks. Start cycle in Neutral. Push reverse button and hold until "R" appears then release. Brakes OFF push reverse button again to engage reverse. Let off Reverse button and let drift ... then use brake if needed. Next shift to first to disengage reverse option.
This shop can rebuild your motor if needed for a great price! http://alternatorsandstartersnj.com/
Bob
Bob
