TriGlide Fuel Mileage
#31
I add a high flow intake but leave the stock muffler for back pressure which adds torque. Then I put in a Cobra FI2000R-CL fuel programmer which operates downstream of the ECM and boosts the AFR to 12.8 to 1.
Then I run 87 octane.
The AFR of 12.8 is the coolest incoming charge and is the easiest to ignite with the fastest burn. Gasoline has 114,500 BTU's irrespective of it's octane. The more that gets burned during the power stroke the more power is made. The higher the octane the harder to burn and the more that goes out the exhaust.
So with the more complete burning and the coolest incoming charge results in more power which in turn requires less throttle to maintain speed.
Included is adding an oil cooler if not standard. Each 3K the engine is treated to remove carbon deposits. Iridium plugs and SE wires. Have not found a source yet for a higher rated coil. Also, I had my fun with wot riding in the 60's and 70's. Now that I am grown up I accelerate modestly and don't exceed the speed limit.
I have modified 15 HD's in my stable since 2009. There are 13 now as I have upgraded some by trading and thinned some for more room to move them around. Each and every one gets the same mods.
EPA highway estimates are 54 mpg on both the TC 96 and 103 (non High Output). HD used to publish that but have since just put the combined city/highway at 42 mpg.
So, yes Santa can bring you 50 mpg in your TC but you must earn it.
#32
Received 3,940 Likes
I would very much like to try what you do (although, I do have a heavy wrist at times).
My question is, do you alter the timing at all, or are you using the stock timing tables?
#33
DK -Never got a pm. I always answer.
As to the timing I leave it stock as I use 87 octane. I won't even use HD's Stage I as it advances the spark timing some.
I would like to do one bike as a power monster. I have watched your video of the 1250 conversion in action. It's awesome.
To bad I don't live closer. I could loan you the Freewheeler to develop some parts.
#34
#35
If you have to de-carbon and engine because the AFR is so rich, it isn't a good thing, bad things are taking place. Have you ever verified excess carbon build up by either a bore scope or engine disassembly?
#36
Triglide with a TTS tuner gas mileagee in town
I remember getting about 30 plus gas mileage before my new TTS tuner. Around town and going on short runs , I am only getting a little over 25 mpg. I need to go on a 100 mile ride to see what I get on the freeway. At 6 gallons that only gets me 150 mile range max. I do notice better acceleration with two up. By myself I am shifting at around 4000 rpms and sometimes take it to 5500 rpm. Max cut off rpm is 6200. Dont go there at all, maybe 2xs since the new tuner. 4th gear to get into traffic. I hope this made sense.
#37
#38
I'm averaging 35.1 to 35.5 @ 80 mph on the highway (speed limit here is 75 ... you do that you'll get run over ... LOL). Around town I'm averaging 33.5 to 34.1 ... I think I get a little heavy handed around town.
I'm using the Dyno Jet Power Vision. Started with a close canned map from dyno Jet and did a bunch of auto tune runs ... I think 7 ... would of been less I think, but didn't see the % learned until Kevin mentioned it ... he was right me old eyes just didn't see it. The last run it said 0% learned, so I quit doing them. I might do a couple when we hit 90* here.
The only reason I care about gas mileage is we have really great rides around me that if you take the "off the beaten path" route, you could need to go 150-160 miles between fill ups. I can easily go 200 miles on a tank now so I'm good.
I'm also gonna purchase a Rotopax 3 gal can .. fume/leak proof and fits lying flat in the trunk, only about 4" of the trunk used. I'm getting this cause we have a couple of bikes with 2.5 gallon tanks that go with us and they always need some one to bring fuel.
#40
