polished front rotor for 2014 trike
I'm getting ready to put ***** shiny wheels and their chrome spacers for the front on my trike. I'm looking for a part number for the HD factory polished rotors. When I go online the descriptions for all of the rotors act like they require specific wheels. I can find one but it only lists it for the left side. Any help would be appreciated. Looking for ideas for a polished rotor and I know you guys have done this.
Sorry for the bad picture but this was the front rotor I chose. It's a Spoke Rotor that you can get about anywhere for about 100 bucks... ebay has them too.
Caution: Do not use chrome bolts that come with these or any other chrome front rotors. Use the stock bolts. Chrome has a way of backing out according to a Harley PHD that I know... He was correct. After a few thousand miles and using blue locktite three of my bolts had backed out and were gone. Others were loose. Was the first time I had heard of such a thing but better to be save. I put the stock bolts back in and they stay tight.
Red loctite does have it's good uses & bad uses. Those that aren't familiar with red loctite should use caution especially on small bolts & screws.
Be dang sure you know what you are doing if you get your hands on green loctite !! Basically ,,,, don't even think about it !! LOL!!!
Just a thought in the empty canyons of my head..... I don't have just voices, they have echo's....
I know times have changed, but way back when I put polished rotors on my '92 Springer. Looked outstanding, but wouldn't stop worth a damn. Local dealer told me I needed Lydall break pads specifically made for polished rotors. Installed them and that did the trick. Do you still need special pads, or have the OEM changed??
How do you like your rear disc covers on your rims. Do they make your brakes run hot?
You know... I got the disc covers from RJ @ no more fried thighs and they are pretty cool. I get people ask about them all the time. No, no brake heat issue... wind is cooling brakes as I ride as usual. Just a bit more to clean.
I've reused rotor bolts all the time with no issues... The new chrome one's just won't stay put.
I know that Kleen Wheels make vented disc brake covers just to keep the brakes cooled. How are your brakes getting air flow without vents? Also would you buy them again?
