Rear Rims Terrible
I used Bell Automotive 22-5-14101-M Monkey Grip Bead Sealer. Worked good after clean up just apply as directions indicate. I would just visit a Napa or automotive parts and ask for a good aluminum wheel bead sealer.
Received 3,940 Likes
Cleaned them with rubbing alcohol, then taped them off, then a little tack cloth and a bit more alcohol. Made sure it was completely dry and then did 4 light coats (a few minutes apart) of Rustoleum Acryclic Enamel Crystal Clear (rattle can).
Still holding up 10K miles and 8 months later. If at some point it does start to go bad, then I will take the time and PC them or hydro dip them.
I purchased a set of take offs, as I wanted to change the dunflops
for a good rain tire. My thought being that I would clear coat them.
But talking to my powder coat shop he said they would send the
rims out to be buffed to a high luster and clear coat them for $100.
each. I think this will make me HAPPY, as I am too old to do a lot
of cleaning........uh.. change that to ANY cleaning!....tenn.
I bought my first set of aluminum wheels (American Mags) in the 60's. Nothing has changed. Aluminum is a porous metal. It can leak if not sealed, and stains very easily. I personally like the look of polished Aluminum over Chrome, I even like polished nickel over chrome. All personal taste. I finally had to convince myself that I would rather ride it than spend way too much time polishing it. We don't have a long winter layoff out here so the trike has very little 'down' time.
Yep, same thing here. Three years later they still look like the day I got them from ***** Shiny!
