Voltage regulator? Again?
Had Harley replace VR less than 500 miles ago. Since then had reverse changed out. Use reverse, and voltage would drop to 6 volts. So I get a battery, and check engine light after riding interstate, then stop at red light? New battery Friday, then Sunday same thing! What are your volts at idle? Highway speed? If I turn on spot lights voltage drops two volts? Oh- 14.5 at highway 12 at idle?
Yeah..dropping to 6 volts in reverse seems too low. You might want test the actual voltage with voltmeter. But, if check engine light came on, that's probably moot.
Received 3,930 Likes
To answer your question...
A bit above 13.5 at idle, and at speed around 14.5
Turning on the spots (at speed) might drop it .5 volts, brakes will drop it around 1 volt.
Reverse drops it to between 10-12 volts, depending on load. Most of the time I remember to idle it up a bit when using the reverse.
Kevin
Last edited by DK Custom; 02-10-2015 at 06:44 PM. Reason: Changed the idle voltage because I confused it with another bike
I made a mistake on a bike a few years back. I told them what I thought the problem was, and then that is all they looked at. I found it better to let them know the symptoms and let them know that whatever they have to do to find out what is causing the symptoms and fix that to be a better plan.
Otherwise they will look at what I told them to look at (which may not be the root cause) and it will check out and they don't have the initiative/motivation to look any further, cause all I told them to do was to look at "x".
Just sayin.
Just sayin.
