Jacking instructions
While the Fix My Hog video is great, it doesn't showing the jacking process. It does show exactly where to put the jackstands however. The video on adjusting the parking brake does show them using a scissors type under the frame and I know that they recommend Hardy Jacks and lifts.
What I want to know is can you use a floor jack on the guard around the diff and belt assembly? The HD parts guy here says yes but others that are very knowledgeable say no. Other opinions??
no pics sorry but I have a little $20 floor jack I use on the rear of mine and I jack up one side at a time I put my floor jack under the loops on the frame bars right under the rear end , jack it up , put my short jack stand under it , just inside my floor jack , the repeat on other side, have done it a few times this way and find it less tippy than jacking in the middle , and the book I read said do not jack on that center belt guard
The owners manual is very explicit on the places you can put the jack on the rear.
DO NOT jack on the housing or the guard.
Place the jacks under the bearing area out next to the wheel. There is a flat area there on both sides. Only jack in those areas on the rear end. Also put a block of wood between the jack & the metal area you are jacking on. The area also has a chain link welded on the housing in the rear. This is for tie down during transport.
Some have made a 2x4 or 4x4 platform to go up between the mufflers & across the trunk area just forward of the rear of the body under the trunk. This then sits on a floor jack.
I don't like that because : #1 It can tip easily, #2 It doesn't jack against the frame other than a small metal strip across the area. #3 You could easily damage the body from something putting pressure on an edge.
The better way is to jack on the frame at the end of the main frame at the pivot of the swing arm with a scissor jack or use a motorcycle jack to lift the whole trike.
If you use anything to lift both rear wheels at one time also tie down the front wheel to the floor for safety, & it will hold the front down & from rolling or sliding around while you lift the rear. I also use a velcro strap around the front brake lever.
