Trunk latch
Yeah, I had the same problem on my 2012 Tri. I sprayed a little SiliKroil in the keyhole and now, it seems to pop out every time. I'm sure that over time, I will need to do this again. I might suggest that you don't use anything that is greasey, because I think grease would capture and hold dust and dirt, which would make it worse. As for slamming the cover, my dealer said that in order for the gasket to maintain a watertight seal, the cover had to fit tightly.
Do what cochon said. I used to have the darned thing pop open on bumps once in a while, that helped a lot.
I saw on another thread to do this; shut the door almost completely, and then shut it with a bump. If you slam it, you pressurize the trunk and it tries to pop back open, and the latch can't fully seat, apparently! I tried it, could hear a hissss from air getting out slowly somewhere. Like a big bass drum, I've hear of folks drilling a hole in it somewhere where water won't get in to let the air out. Or just shut it normally and then give it a bump with the heel of your hand to let the latch do it's thing after the air gets out.
The day I rode my 2015 home, a guy honked at me and told me my trunk was open ... three days later it was at the dealer for add ons, and I told the tech about it ... he took the latch apart, lubed it and adjusted it ... works great now ... no fancy closing procedure ... I do always lock it though, I keep tools in there.
Also when closing best to just push it in with even pressure to latch, slamming does not work as work as the there is no air damper to allow air to escape fast enough for slam.
