Slip-ons for a 2012 Triglide
I did look to see if there was another thread like this one but I could not find one. I am looking for suggestions for changing my exhaust to try to disperse some of the heat and maybe get a little more power. I do already have a FP3 fuelpack in hand hoping this will work. Any other suggestions for what type pipes will work on the Triglide?
Thanks!
Harleygirl
Thanks!
Harleygirl
Thanks!
Harleygirl
Thanks!
Harleygirl
If you change the header you can also use most all the ones for the touring models. But you will need to buy the extension adapter pipe to get the extra length on the right side to reach the muffler.
While the Fuelpack may work for some heat reduction, It isn't the best idea for the engine as far as a correct tune. The best way to do this is with a method to actually flash the ECM so it may correctly tune the engine & not just add more fuel overall. Some have good luck with the Fuelpack, I just don't feel it does the job I expect .
The heat in the headers is from exhaust gas which is about 1200* Changing the mufflers, removing the cat, or changing the headers won't make any difference in the 1200* A new exhaust system with a fuel pack of one kind or another MAY reduce the heat 100*. Moving the position of your foot / leg will make a much bigger difference. Harley Floorboard extensions are under $100. I put CFR 4" Megaphones on both my wife's 2014 Tri-Glide and my 2015 Freewheeler. They fit without any adapters or modifications. I put them on because they are LOUD. We don't have any clearance problems, we don't go up or down driveways at 90* Good Luck
