Cfr exhaust
I bought the knock offs a little while back & did a very short ride, & they were to loud for me. After reading all the posts on these I thought I'd give them another try. I installed them & it didn't fire right up like usual. I rode it again & it just didn't have the take off as with my other mufflers. Bike just didn't run as good. They sound great at idle, but just to much for me at the higher speeds. I removed them & put my others back on & the trike runs good again. Anybody experience any performance loss with yours?
been looking myself, i have a freewheeler on order, when you say other which exhaust are you talking about, thanks
D&d mufflers
I emailed D&D and this is what they have.
Slip-on Mufflers for the New Harley
Free Wheeler Trike
Stock Mufflers are 27" long and our mufflers are 27" long before any tips and mounting is the same.
408 and 536 with NEW Vortex Wrapped Baffle
408-11TSVQ 3 ½" Black Muffler Straight Cut
408-12TSVQ 3 ½" Chrome Muffler Straight Cut
536-11TSVQ 4" Black Muffler Straight Cut
536-12 TSVQ 4" Chrome Muffler Straight Cut
New Slip-on Mufflers with Vortex Wrapped Baffle for the Interchangeable End Caps Sold Separately
Best End-Caps to use are the Fish Mouth or Straight Cut
621-11TVQ 3 ½" Black Muffler Straight Cut
621-12TVQ 3 ½" Chrome Muffler Straight Cut
622-11TVQ 4" Black Muffler Straight Cut
622-12TVQ 4" Chrome Muffler Straight Cut
Free Wheeler Trike
Ronbo1 (05-10-2017)
I have D&D Exaust 3 1/2" touring mufflers with the 2" Vortex baffles and the short straight cut Billet end caps installed on my Freewheeler. They sound great a nice throaty rumble not over the top loud but can be heard and the Freewheeler has no power loss at all. Other than the mufflers and a K&N factory air filter replacement my Freewheeler is bone stock and the performance is just fine.
Ride Safe,
Bill G
Free Wheeler Trike
Free Wheeler Trike
These mufflers sound awsome a throaty rumble not over the top loud but can be heard. No power losses at all, my Freewheeler trike is stock other than the D&D mufflers and a K&N factory replacement air filter.
I did not choose the 4" D&D touring mufflers because they have the 2 1/2" vortex baffles and I wanted specifically the 2" Vortex baffles that the D&D 3 1/2" mufflers have in them.
I posted below a high quality sound clip from D&D web page on the 3 1/2" touring mufflers with the 2" Vortex baffles. My Freewheeler mufflers sound very close in sound if not the same as this video.
Ride Safe,
Bill G
Yes and there sweet top quality mufflers. I love them on my new Freewheeler Trike... The D&D 3 1/2" Touring mufflers with the 2" Vortex baffle. The end caps I got are the straight short rounded billet caps which add about 1 1/4" to the length of the mufflers placing the mufflers still nicely behind the chrome bumper.
Ride Safe,
Bill G
2014 Harley Davidson Ultra Classic with D&D's New Slip-on 3 1/2-inch Muffler - YouTube
Ride Safe,
Bill G
thanks for the video, i looked everything up on there site but the exhaust numbers and end cap numbers are different then on the page shown here, if you don't mind could you put up the exhaust numbers and end caps numbers that you ordered, I'm going with this set up also, beings I've had D&D in the past, thanks
D&D chrome 3 1/2" touring mufflers with 2" vortex baffles part# 621-12TVQ
Short chrome rounded billet end caps for the 3 1/2" mufflers part# 603-12EcapS
Make sure to order 2 end caps. (Note) The allen bolts that hold the end caps on are tedious to get in. Go slow not to scratch the rolled ends or edges of the end cap on the inside edge. I taped mine with thick duct tape as not to scratch. Then I removed the residue from the tape with lighter fluid and then cleaned the hole muffler with Windex before starting the bike.
(Note) Flip the back muffler brackets lips facing down (see pic of muffler bracket and support rubbers flipped) and support rubbers to match it will make the muffler install much easier. The back bolt is a pain in the *** and this mod or bracket flip makes re-assembly go a lot easier. It now will be much easier to get to and tighten the bracket bolts. (Note) The rear muffler bracket will work fine either way lips facing up or facing down.
Also you will not need the black leveling spacers D&D send to make the mufflers look even with the bags on a touring bike from a side view. You will need to re-use the short original back muffler bracket bolts. (Note) The longer bolts that D&D send with the mufflers to go through the black spacers mentioned will not be needed on the Trike application). You will see what I mean when you install everything. Also D&D recommends there muffler clamps, put them where all the expansion lines are covered and tighten snug, heat cycle and re-snug.
Best of luck & ride safe,
Bill G
