Stock suspension lift on 2015 TG's??
I don't know if HD did something different or not, but my 2015 does sit a bit higher than my 2012 did. I'll get flamed big for this, but I see no reason to have the lift. I added one the 2012 and my wife didn't like it because it made her slide forward on the seat so off it came. I put it back on and didn't tell her and she asked me on the next ride why I put the lift back on, so she could tell and off it came again. In about 20K miles of riding with the bike in the stock configuration I have possibly just touched my mufflers on something about 5-6 times by watching how I drive. So no lift for me for a lot of reasons and if you want the bike to handle better, put a rear 2 wheeler tire on the front the results are much better than the lift IMHO.
Well, I have to drive about 1 1/2 miles on gravel roads to get on pavement so the extra lift will be needed. Plus I have 600 feet of gravel driveway that would make it tough not to drag once in awhile.
You have a valid reason to have a lift, I have the same type of driveway, but go out onto paved road. I've never drug on my driveway. There are likely more people who like the lift than there are who share my position. I have a real nice and hardly used Tglide Stuff lift you could buy for a reasonable price and that is the one I would use, if I were going to use one.
I had a '12 Tri with the lift kit installed. When I purchased a '14 Tri I measured the clearance from ground to bottom of the trunk (between the mufflers) and the '14 measured about 3/8" more without the lift kit.
After scraping every time I came off my lift table I decided to install the lift kit. Did not have this problem since the install.
Also after the install of the kit I checked for differences between the '12 and '14 stock shock plates. There is no difference they are exactly the same.
To lift or not to lift
That is the question ... and it's a personal as boxers or briefs (pardon to the ladies)
I did the lift mainly cause I didn't like the "load in her shorts" look on the 15 Tri ... Dk's customer service gal called me the day after I ordered online and asked a lot of questions about my riding style and expectations about the lift ... she recommended the comfort lift, so I had her change the order ... Very professional and knowledgeable customer service.
I can't speak to the standard lift as I went with the comfort, but, I was pleasantly surprised at the more comfortable ride I got from the comfort lift as well as the more ascetically pleasing look of the trike ... took awhile to find the optimum to me rear wheel pressure and shock air pressure, but, once this was found, I love the lift. I "feel" like I get less right to left bouncing ... but it could just be me ... and I'm sure I get more absorption of the bumps by the shocks .. probably due to the slight angle change on the shocks.
A Big plus is the less bottoming out over speed bumps and driveways.
