Dang seat screw!!!
#41
I bought this extended seat bolt from Custom Dynamics. Not cheap but it solved my problem. I'm pretty sure there are cheaper options like a shoulder bolt.
https://www.customdynamics.com/exten...on-motorcycles
frenchbiker (01-07-2018)
#43
I had one of like this from J&P and tightened it up as tight as I could get it. Went to take the seat off a month or so later and it was gone. Either someone "borrowed" it or it worked loose. Now I just use the milk jug trick. If you get one of these that you can turn in with your figures, better check it often to see if it is still tight.
#44
graygoat (01-08-2018)
