Even if you go with a catch can (which can be pretty cool, I've seen all sorts of cans used for them)...it is still a drill & tap job with the AN BS.
IMO the AN fittings make for a cleaner looking install, I'm not much of a rubber hose and hose clamp type of person, to me it looks cheesy. I'll use hose clamps with braided when I can't use an AN fitting in an application.
Kevin, which breather kit is recommended for a stock A/C system for a 2011 TriGlide?
I have the stock A/C system with a K&N filter replacement.
With the stock air cleaner (with or without the K&N filter) the Twin Cam Discrete, at this LINK, is what will work. It allows for filter placement anywhere you'd like.
anyone happen to have a PDF of the instructions to install this? I'm considering it, but I'm about as mechanical as a rock and want to make sure it's something I can do.. I'd like to get this sort of stuff done to my new bike as early as possible and while it's still brand new!
Send me your email addy by PM or email to the address below. Let me know which products you want the instructions for and I'll email you the PDF.
