Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Rotor scored heavily
Old 06-29-2015, 06:30 AM
Steve On 3's Avatar
Steve On 3
Steve On 3 is offline
Default Rotor scored heavily
Was checking my air pressure this morning and noticed my left rear rotor is heavily scored. At first I thought parking brake but on the 14's and 15's the book says the parking brake goes to both rear brakes. It's under factory warranty but at 10k mikes, shoulld not be all chewed up.
Thanks
Steve
Old 06-29-2015, 09:33 PM
Fearless (old nickname)'s Avatar
Fearless (old nickname) is offline
Default Turned mine this spring
Old shiney got the rotors touched up this spring no gouges but ruff ridges maybe new ones in spring. ride safely fearless
Old 06-29-2015, 10:26 PM
FuzzyWuzHe's Avatar
FuzzyWuzHe
FuzzyWuzHe is offline
This happened to mine ... turned out to be a stone in between the rotor and the pad ... pull the wheel and pad and check for stone or gouge where stone was ... probably what happened to yours
Old 06-30-2015, 07:53 PM
wijr1949's Avatar
wijr1949
wijr1949 is offline
My '11 did that, too.
I pulled the rotors and had them touched up at O'Reilly's (They did it free 'cause I'm a GOOD customer) and got new EBC pads.
All is well now.
Old 07-01-2015, 03:27 PM
Redcrow's Avatar
Redcrow
Redcrow is offline
All is well now.
O'Reillys can turn the rotors for the tri-glide? Huh.
Did you just have them skim the surface?
Old 07-01-2015, 07:48 PM
wijr1949's Avatar
wijr1949
wijr1949 is offline
Yeah, he just did a clean-up on them.
There was plenty of thickness left.
Old 07-02-2015, 02:13 PM
oldtimershockey's Avatar
oldtimershockey
oldtimershockey is offline
Back brakes were squeeling when I come to a stop on my 2013. 1 rotor was scored a little bit. Dealer changed out both rotors and pads under warranty.
tylerfj24
Milwaukee Eight (M8)
14
07-14-2018 04:07 PM
ThaGlyde
08-25-2016 08:34 AM
Bowhunter61
04-04-2010 10:15 PM
SeniorChief56
09-07-2009 10:01 PM
pleasants9
06-19-2009 08:50 PM
Quick Reply: Rotor scored heavily
