Trike lift kit
Trike lift kit
I have a lift kit I want to put on my 2011 Tri glide. My question is I'm very mechanically inclined but when I looked under the trike I noticed the 4 bolts you have to loosen and take off are held on by long bolts that seem to pinch a spot on the axle. So if I loosen and remove the bolts it looks like the axle will move and shift. Am I correct? Doesn't seem any other way to install these.
Received 3,940 Likes
There is nothing in the installation process of either one of our Lift Kits that requires all the pinch bolts to be loosened, allowing the axle to shift position.
LINK to our Standard Lift & Comfort Lift Kits.
bluedemon06
35
02-17-2017 12:59 PM
Bucket list Trike
19
04-12-2014 01:57 AM
