Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Inexpensive Tank lift and floorboard extension
Old 08-04-2015, 12:17 PM
Tryker Dude's Avatar
Tryker Dude
Tryker Dude is offline
Lightbulb Inexpensive Tank lift and floorboard extension
I spent less than $10 for all parts needed for these mods. Yea, I know; it seems like the cheap way out, but I am on a very tight SS budget. And it works! I should add that I only raised the rear of the tank 5/8" because any higher interferes with my junk comfort. I'll find out on future rides how my reserve distance is affected.
Attached Thumbnails Inexpensive Tank lift and floorboard extension-p1000207.jpg   Inexpensive Tank lift and floorboard extension-p1000210.jpg   Inexpensive Tank lift and floorboard extension-tank-lift.jpg
Old 08-04-2015, 01:27 PM
Fearless (old nickname)'s Avatar
Fearless (old nickname) is offline
Looks good as long as it works you can always make it pretty! Great job Fearless
Old 08-06-2015, 07:25 AM
sweet johnnie's Avatar
sweet johnnie
sweet johnnie is offline
i can't tell what you did to extend the floorboard,unless its a spacer and longer bolts,i agree with saving money when you can on stuff like this....
Old 08-06-2015, 08:24 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Oogie Wa Wa is offline
How did you raise the back of the tank? Or more important in my case, did it raise the front of the seat an equal amount? I'm thinking that doing so, about 1/2" might help in my case. Thanks.
Old 08-07-2015, 01:17 AM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,081 Likes on 3,483 Posts
If you go to a hardware store where they have the drawers of chrome bolts, springs,etc etc, they will have spacers. I got the chrome 1/2" long in the correct bolt diameter.
I think they were like $1.10 each.
I wouldn't go over the 1/2" raise.
Old 08-07-2015, 10:25 AM
Tryker Dude
I used a couple of 3/8 self locking nuts that are about 5/8" thick under the bottom of the tank bracket. 1/2 " or 5/8" is about all I would go with the rear lift. Any higher really puts a cramp on the jewels. And yes, it does raise the front of the seat proportionally.
Old 08-07-2015, 10:34 AM
Tryker Dude
If you enlarge the floorboard photo to max you'll see that I used a couple of oversized nuts as spacers at both mounting locations and the corresponding longer bolts. This allows the floorboards to be out an inch farther. Be sure to use the blue Loctite. I've ridden about 1,500 miles since this mod with no problems.
Old 08-07-2015, 07:15 PM
Oogie Wa Wa
Thanks, that's what I needed to know.
Old 08-07-2015, 08:36 PM
FuzzyWuzHe's Avatar
FuzzyWuzHe
FuzzyWuzHe is offline
Does it bother you that you are pirating a copyrighted product, from one of the forums sponsors? Just saying.
Old 08-08-2015, 07:27 AM
hedgie57's Avatar
hedgie57
hedgie57 is offline
I believe Fat Bottom Girl is also copyrighted. I don't think making your own parts would be infringement or illegal.
wijr1949 (06-20-2019)
Quick Reply: Inexpensive Tank lift and floorboard extension
