Oil Leak
Oil Leak
I've had some down time this Summer due to a bum leg. After my 2012 Triglide sat for a couple of weeks, I noticed a puddle of oil spreading out on the floor under my bike. Now, I've owned a lot of Harleys over the years and while some may have leaked a little occasionally I had never seen anything like this since the early Evo years. I finally felt good enough to crawl under the bike this week and I found that every bolt in the oil pan was loose. Most were only finger tight, and a couple had backed out significantly. Never saw this one before and I thought I'd pass it on. Just one more thing you might want to check before you go on a long trip.
Ride Safe
Mike
Ride Safe
Mike
Mine last winter
When I did my post season on my 09 I noticed the same all my bolts were loose as well as the clutch side of the tranny. I don't know if this is a problem or just poor insp. practices but I keep a close eye on them know. If they get loose again I will remove the whole thing clean and reseal. ride safely fearless
Ride Safe
Mike
Ride Safe
Mike
Here is the bulletin https://app.box.com/s/m0930kjxtuo4624n2b3n.
