Annoying oil leak up front
Good day everyone, I've been chasing a very persistent oil leak up front somewhere around the oil filter or cooler adaptor plate. At first I suspected it was a leaking oil pressure sending unit but have ruled out that possibility. Has anyone had this problem and have corrected it. It's not a big leak but more of a slow seepage. I've also checked/changed the filter several times to no avail. Also it's not the cooler hoses. Thanks in advance for any help.
Observation of my experience. When I change the oil, some always seems to drip down from the oil filter after removing, then into the oil cooler fins. I could not wipe all of it off, and it would drip. I have since started using a weed sprayer and the green parts cleaner to spray into the cooling fins, followed by a good rinse with water. Solved what I thought was a leak. Just a thought.
I have a JAGG 10 Row and have the same exact symptoms. Today it was 3-4 drops. It's been 1-2 drops for a while. For Big Blue, it's the oil cooler adapter leaking this time. Last time I had a leak in this area, it was the clutch cable leaking past the o-ring and running down the cable to the low spot, which coincidentally is in the same place as the oil cooler adapter leak.
I had to replace the oil cooler adapter on my dad's 09 Triglide a couple years ago. He developed a oil leak as you described. I first tried replacing the gasket, it still leaked. I bought a new adapter PN 63059-09, it hasn't leaked since. It looked like the old adapter warped which caused it to start leaking.
Ouch, thanks msocko3, that's what I was thinking also and afraid of. New adaptor plate and hoses almost $300. I've already tried the gasket replacement without success. Being on a very limited fixed income I'll have to save up for the parts and live with the leak for a bit longer. Thanks for all of the replies and suggestions.
No reason to replace the hoses if there isn't anything wrong with them.
