Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
TriGlide Rear Shock Replacement Procedure
Old 09-07-2015, 01:11 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,271 Likes on 11,143 Posts
Default TriGlide Rear Shock Replacement Procedure
Before I ordered the Progressive rear shocks, I thought I'd check out the install procedure in the TriGlide service manual supplement. So, the first step, for my 2012...is remove body!! Really??
Has anyone done this themselves? Did you really need to remove the rear body??
Old 09-07-2015, 09:57 PM
Moneywoes's Avatar
Moneywoes
Moneywoes is offline
No you don't have to remove the body. You have to get the Trike in the air high enough that you can get under it and reach up to get at the top shock bolt though. If you use a air ratchet on the upper bolt don't back it out with the ratchet so far that the ratchet gets caught between the bolthead and the trike body. Theres not enough room to back the bolt all the way out with the air ratchet. You'll want to use a open end wrench the last half.
Old 09-07-2015, 10:27 PM
Frostbite's Avatar
Frostbite
Frostbite is offline
Received 3,407 Likes on 1,541 Posts
Which shock are you going to? Thinking of doing this on the freewheeler if possible...
Old 09-07-2015, 11:39 PM
TriGeezer's Avatar
TriGeezer
I don't know what would go one the Freewheeler. But, the Progressive rear shocks for the TriGlide are:
Progressive Suspension 416-1643A 13" High Performance Replacement Air Shock
Old 09-08-2015, 11:19 AM
Frostbite's Avatar
Frostbite
Thanks for the come back. Google says they'll fit, but was looking for something that wasn't air. Don't have much faith in a system that leaks straight from the factory...
Old 09-08-2015, 11:27 AM
TriGeezer's Avatar
TriGeezer
I haven't had any issues with leaking air after 3 years. But, if you go on the Progressive Suspension site, they have airless shocks as well.
Old 09-08-2015, 11:57 AM
Frostbite's Avatar
Frostbite
They show one - 444-4074B - for $625. Kinda want to do more shopping before I take that big a leap.
Old 09-08-2015, 12:00 PM
Frostbite's Avatar
Frostbite
Must be a new one - this is what google shopping tells me:
No results for progressive 444-4074B
Old 09-08-2015, 07:09 PM
neon65's Avatar
neon65
neon65 is offline
There was a thread a while back on this. I installed the Progressive 444-4020B black 13" heavy duty. Put three turns preload and haven't touched them. Also mount them upside down so you can get to the adjuster if need be....
Old 09-08-2015, 08:25 PM
Frostbite's Avatar
Frostbite
Originally Posted by neon65
There was a thread a while back on this. I installed theve 444-4020B black 13" heavy duty. Put three turns preload and have Progressin't touched them. Also mount them upside down so you can get to the adjuster if need be....
That sounds like what I'm looking for. Should be no reason that won't work on a freewheeler. Thanks guys!
Quick Reply: TriGlide Rear Shock Replacement Procedure
