Anyone using aftermarket Mid Frame Deflectors
Anyone using aftermarket Mid Frame Deflectors? I tell ya, highways I'm fine, but when we get back to the city, the rising heat is too much. I'm running catless headpipes, even still, it's like riding in hell! Think I'm gonna put Wards Fans on too.
There are two. Capt.Itch Crotch Coolers and RJS Originals. CrotchCoolers are simpler to use, work very well in slow & go traffic. RJS Originals are a bit more complicated to install, but not bad. RJS seem to wick out hot air better at speed. Both are high quality products. I've owned both. RJS on the 2010 TG and Crotch Cooler on the 2012 TG. Like both. Very slight edge to Crotch coolers for easy install and removal. Again, both will make you happy. Just research them and decide. Good luck.
If you decide to go with our product we do recommend that you remove the plastic ones. It will allow our crotch cooler to mold in to the frame and settle down after a 100 miles or so. Any questions just let us know. Thank you Itch ..
Tangle Eye
05-03-2013 09:45 PM
