Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Triple tree air deflector
Old 11-09-2015, 04:41 PM
cmc seabee's Avatar
cmc seabee
cmc seabee is offline
Default Triple tree air deflector
Anyone using one of these from "Street Glide Wind Deflectors", and if so how do you like it ?
Old 11-09-2015, 09:44 PM
TheBobs's Avatar
TheBobs
TheBobs is offline
I do and feel it does a good job.
Old 11-10-2015, 04:01 AM
Fusionfool's Avatar
Fusionfool
Fusionfool is offline
I have one, but have removed it to maintain good air flow to the engine. It came with the chrome fork wind deflectors that I also do not use anymore.
I purchased through eglidegoodies, and see that they no longer offer them. Or at least can not find them.
I liked them for fall riding, but not so much in the summer heat.
PM me if you would be interested in the set.
Old 11-10-2015, 05:37 AM
NHBAGGER's Avatar
NHBAGGER
NHBAGGER is online now
Running one and not sure how much it does as I also installed a 1" taller shield for the Fall. Between the two it did help some, but there is still a decent amount of air that comes from under the fairing. Maybe the fork deflectors would help that?
Old 11-10-2015, 11:34 AM
cmc seabee's Avatar
cmc seabee
Thanks for the replies. I really appreciate it.
Old 11-10-2015, 08:36 PM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,081 Likes on 3,483 Posts
I made my own just like that one out of aluminum. I take it off in the summer when I can deal with the air, but put it back on come cold weather.
It really does a good job, & I also have the deflectors on the forks that help a great deal.
Old 11-10-2015, 09:46 PM
dw2169's Avatar
dw2169
dw2169 is offline
Default Air Deflector
I have one on my 2011 trike and I think it really helps. It forces air down on the engine instead of letting it go over the gas tank. I think it helps keep the engine cooler in the summertime.
Old 11-11-2015, 03:39 AM
Fusionfool's Avatar
Fusionfool
Not that I am doubting you on the theory it cools better, but using the Power Vision. Have you run trials with and without the baffle?
I am curious what you found for engine temp with, and without baffle. I found it was just a tad higher with the baffle, and I believe that is because it also blocks a bit of cooler air that would have going to the AC.
I also have the Tank lift by DK, and may be there is a difference there.
Old 11-11-2015, 06:09 PM
livin2ride2's Avatar
livin2ride2
livin2ride2 is offline
If you are planning to put those on your 2015 Tri, I think you are going to find that they will only fit up to the 2013 models.
Old 11-11-2015, 06:24 PM
cmc seabee's Avatar
cmc seabee
I emailed the guy who manufactures them, and he said he now makes one to fit the 2014 & 2015 Tri Glides. Cost is $65.00 shipped. Just wanted to know if anyone else has used it on their trike before I ordered it.
Quick Reply: Triple tree air deflector
