High oil pressure?
High oil pressure?
I searched and couldn't find anything on this, but anybody experience oil pressure running too high? The last couple of days my 13 TG oil gauge is showing idle at 30 and with throttle about 45-50. Dealer's not sure what it could be. My first thoughts were bad sending unit, bad gauge or oil line pinched or obstructed somehow, maybe in the cooler?
its not MC related, but I would think same problems would be culpart on a MC...
http://www.powertraindirect.com/what...-in-a-vehicle/
Hope it helps.
Hope it helps.
Hope it helps.
Hope it helps.
Talked to the "good guy" at the dealership, and he said it's probably the oil pressure relief valve. Have to get to the cam plate to replace...about a 5 hr job.
Will give an update after I get it in Monday/Tuesday.
I found 2 web sites that sell aftermarket oil pumps and parts. According to them:
Normal cold idle oil pressure is 40 to 50 pounds
Warmed up at 2000 rpm normal is 30 to 40 pounds
Warm idle is around 10 pounds.
This may vary depending on Dino oil or Syn, temperature and viscosity of oil. Sounds like you may not have a problem
