Driving /spot lights on a freewheeler
Received 3,940 Likes
Looks like you got your wiring done! Looking good!
You like how white those LED bulbs are? Have you been out of the road yet to see how well everything is lit up?
On Harley Davidson printed instructions, they have warned of exceeding the total amperage of accessories on a motorcycle. For example, on their -J05516.PDF, their H-D halogen bulbs "...require up to 4.56 amps additional current from the electrical system." and their H-D LED bulbs -J05236.PDF "...lamp kit requires up to 4.6 A current from the electrical system."
What is the amperage of your Premium White LED Bulbs P/N DK-05-PL-LED ?
A question Kevin ~what's the amperage on your LED bulbs?
The stock HD headlight pulls about 4.5 amps, our LED headlight bulb draws .8 amps. So that is a drop of 3.7 amps.
The Pair of LED bulbs you asked about come in right under 1 amp.
By switching to the DK LED's vs the HD bulbs (all 3- the headlight and the auxiliary lights), not only will it be better lighting, but a savings of 7.2 amps...less load on the stator!
