Setting Alarm/TSSM sensitivity on TriGlide
I am not big on audible alarms. most people don't pay much attention even when they do go off. But I put the audible module on my 2015 TriGlide to make a racket when/if someone trys to crawl on it when parked.
Problem is, I can roll and bounce the bike around a LOT before it does anything. I can/have set off the alarm just to test it, but it took a pretty good shaking to do so.
I found instructions on how to set the sensitivity on TSSMs with a pushbutton fob, but cannot find any instructions that tell me how to set sensitivity with the button-less fob.
Is the process the same (and just omit the step of pushing the button)? Does anyone have button-less fob instructions? Can the sensitivity even be adjusted on these systems? Where do babies come from?
Help?
Help?
Help?
Help?
I've pushed my dad's 09 with siren out of the garage and back in without the fob present and never once did I set the siren off.
I don't worry quite as much with the TriGlide gettin taken as with the other models. Gonna take a lot more logistics to haul that lard a$$ thing away. Secondly, I use a simple disc rotor lock, that prevents it from being rolled away. The alarm disables the ignition from being started as well. As a precaution, if you use a rotor lock. I run a bright colored string from the lock to the throttle grip so I don't forget to take it off before it's removed. I've seen some folks make a REAL quick stop trying to ride away with that lock on.
Yeah, I've used rotor locks and chains on most of my previous bikes, and am not as worried about theft as it may sound. But, I am most concerned about someone just releasing the brake and pushing it or letting it roll.
I was just kind of hoping some ingenious soul out there had an idea for a little more elegant solution.
