Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Barnett +1 Clutch and Hayden Chain Adjuster
Old 06-09-2016, 09:01 AM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Administrator
Received 2,035 Likes on 1,103 Posts
Originally Posted by woodman
Hey Mr Wizard,
Are you still satisfied with your mix of ATF and Formula + on your Barnett?
Yes sir...
Lubricates very well and keeps the primary a bit cooler because it's so thin but not thin enough to seep gaskets.
Old 06-10-2016, 06:06 AM
cochon's Avatar
cochon
cochon is offline
Hey Mr Wizard,
I am also still using that same mixture with no problems whatsoever.
Old 06-10-2016, 06:52 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is online now
Received 6,349 Likes on 3,281 Posts
Just installed the +1 in the 07 with their spring, I like the way it grabs...I went with Redline primary fluid....might just use Type f next time but all is working well and my Hayden tensioner with About 20k on it looked great. Had to play with my cable adjustment a bit but now works fine.
Old 09-24-2016, 08:28 PM
usmc68's Avatar
usmc68
usmc68 is offline
My primary is making a lot of noise so I'm going to put in the Barnett clutch and the hayden adjuster . What after market compensator do I need to go with this on my 2112 Tri-Glide? Brand and a part # would be great. I plan on using the formula+ and Mobil 1 mix .I have 32,000 miles on bike so I'm sure the compensator is bad ,Sounds like marbles in primary at times.
Old 09-25-2016, 02:56 PM
usmc68's Avatar
usmc68
usmc68 is offline
I have everything tore down the adjuster had some markings from chain on it and the compensator had some skuff marks and looked rusty in some spots so I guess I need to replace all . I've never had a problem finding netural but noise in primary is very bad at times .
Old 01-25-2017, 02:53 PM
JWKHD1's Avatar
JWKHD1
JWKHD1 is offline
Default 2015 TriGlide clutch
This question is for Mr.Wizard. what Clutch kit (extra plate) is recommended for the Harley A&S clutch in the 2015 Tri Glide . Or what complete clutch. Looking for more grip and smoother engagement.
Thanks,Wayne
Old 01-25-2017, 03:09 PM
Mr. Wizard's Avatar
Mr. Wizard
Administrator
Thanks,Wayne
Wayne... I know of no extra clutch kits that is available for the A&S stock set up. The main issue with the A&S is the weak three coil spring pressure.
Old 03-26-2017, 10:19 AM
WRE4U's Avatar
WRE4U
WRE4U is offline
Thumbs up
Mr Wizard,
Great info and it came at the right time for me!! A couple of questions....not really needing exact costs, but a working mans idea, or analysis of cost of materials, parts, hours from start to finish ( my indy has a price that he will do it for) or any other info you would care to share on this project. Do you have any idea on what a HD dealer would charge? Thanks so much for your article and help!
Old 03-26-2017, 10:41 AM
Mr. Wizard's Avatar
Mr. Wizard
Administrator
Originally Posted by WRE4U
Mr Wizard,
Out of pocket costs for this job will average about $300 or less. Time value will run between 2 to 4 hours depending on your skill. It actually took me longer to write this than do the work.
As far as a dealer... man, who knows!! There really isn't much more to it than changing the clutch out and ad an hour for the chain adjuster.
WRE4U (03-26-2017)
Old 03-26-2017, 10:55 AM
WRE4U's Avatar
WRE4U
WRE4U is offline
Great! Thanks so much! I have a buyer for it, and I want to make sure I give him correct information. My indy who has been great to me says around $700 which sounds fair, I want to take off $1000 for the buyer to make sure he is happy. Here is the bike:
http://www.ebay.com/itm/252831036837...84.m1555.l2649
Mr. Wizard (03-26-2017)
Quick Reply: Barnett +1 Clutch and Hayden Chain Adjuster
