Just ordered wards cooling fans
I think that I would have found another way to test if they were waterproof, though... just sayin'
I think you will be pleased... Have never had an issue with mine, and on a hot day in FL in creeping traffic, they have made a noticeable difference.
I found these fans helped so much, I cool down as I go into towns, and slower speeds. It was opposite before, I would clime quickly to 250° + on oil temp. Now with the fans normally will stay around 240° max.
Now that I have a Power Vision, it allows me to monitor engine temp, and that is where I see real time of the fan performance. If I am on the highway aggressive ride, my ET can clime to 150 easily, then as I reach a town and slow down the fans will quickly lower the ET to 230 range.
I took them off my 2010 Street Glide when I traded it in, and installed them on the 2015 TriGlide.
They do make a world of difference in removing a lot of heat, but my EITMS still activates when stopped at a red light.
I heard that the newer Rushmores activate the EITMS at ambient temperature instead of head temp., so that's most likely why.
I still smile when people ask me "what the heck is running" when I shut the bike off.
I always tell them it's my turbo charger fan cooling off the turbo.
Usually get really weird puzzled looks from them.
Got a set and they are setting on the "To Do Bench" for the wife's bike. Have not had chance to read the instructions yet but based on a prior post --- do I need to source a longer mounting bolt before I dig in to get r' done?
Glaciers are receding and the bears are coming out -- time to ride!
I have a very large horn and only needed to add a longer stud.
It's easy and straight forward to install.
woodmnctry (04-08-2016)
Yep, the late models activate EITMS on ambient temp, you can manually disable it, its definitely not necessary with the fans running.
