Tri-Glide Trunk Removal
Received 3,930 Likes
There are 6 or 8 bolts to remove the body. Plus you have the electrical connections. The step by step on how to is in the service manual.
Whatever you do, do NOT jack up the trike like in the video above. The guard under the rear pulley is NOT made for that.
BobRed0965 (03-29-2016)
First off, you need your shop manual and trike supplement. Body removal is outlined. It is very easy and quick, 15 minutes. You just need a extra person to lift it off. It's not heavy. If you do take the body off, it is a good time to seal it at the bolt locations, and where the tour pack mounts to it. If you haven't already done it, it is also a good time to put on the lift kit. I wish I had pulled the body to do the lift. It is also a great time to visually match components to what you read in your SHOP MANUAL and SUPPLIMENT and take photo's.
dogwheat
01-19-2014 04:41 PM
