Stock seat question
Rax, I think all the one piece touring seats will fit from '09-'16. I don't think there was any changes in the mounting at all.
I know they all fit my '12. I have tried everything through '13 on it. That should be anything but the Saddleman Road sofa. They say for Tri Glides, but after you get it & it doesn't fit correctly, you get to argue about who is going to refund your money.
Raxus (04-22-2016)
Received 3,931 Likes
That is a different part # than the 13 and earlier Tri-Glides and 2 wheel Ultras.
Not saying the earlier years won't fit, but usually HD does not change something they don't have to.
I know on the 14 and later the rear mount is different in relationship to the body...not sure if the seat position stayed the same and they changed the body or mounting spot on the frame only, or if is also a change in the seat.
I would go to an HD dealership and see if they have a 13 or earlier and a 14 or later and see if they swap out...that is the only way to know for sure. There's lots of stuff in the book that says it won't fit on xyz model, but it fits just fine.
edited: Sounds like harleygeezer already did the work of testing for you and it fits.
Raxus (04-22-2016)
The seats from the 09 models up will fit. I am using one off a 2010 that I had reworked at Mean City Cycles on my 2014 Tri Glide. The difference in the seats starting in 2014 is the rear portion of the seat for the passenger is a little wider and longer. I have my original seat that came off my 2014 tri glide I will sell you for a nominal price if you want it but any seat from 09 up will work.
Raxus (04-22-2016)
Rax
grayjoe
04-04-2017 07:40 PM
