Jump Start & Battery Removal
Can any show me EXACTLY where I can jump start this beast thru the starter? Someone told me awhile back I can just jump thru the starter without connecting directly to the battery terminals?
Also can anyone direct me to a video on how to remove the battery? I can take off the 2 torx screws to the tray but damn if I can find where the tray is connected to so I can take it off completely to get to the battery. Right now all I can do is just lift it up enough to get jumper cables in there.
Any help would be much appreciated!
Rax
Rax
Sometimes when I try to start my trike it'll turn over once then click. Then the trike acts like I turned it off and on again (infotainment system reboots, fuel pump turns back on again, etc) then does nothing but click. This normally happens after I have rode a bit, turn it off (like getting gas) and have to restart the trike right after I have turned it off. Every once in awhile if I take out the main fuse and put it back in that will work, but not very often. I have taken it to the dealer but they say the battery is good and the charging system is fine. The only way I can get the thing started again is by jumping it.
One other thing that happen this last time. When it started to click and I turned it off, the infotainment screen stayed on..no music just the Harley logo on screen..with everything off.
Dealer also suggested I always have the battery tender on when not riding it. Great advice except when I am out of town and staying overnight. Been doing this (except the last thing with the infotainment system) for over a year now.
Rax
Rax
Rax
Rax
I have seen several bikes and trukes having a stick on igntion switch which will run the battery down. Next time you start it use your finger nail behind the switch and pull back on it slightly. Thus removing the contact to the starter.
You having to jump start the battery is wrong. There is something else going wrong with your trike. Take it back to the dealer and have them check it out. Is it throwing any cides?
The dealer said the only codes it was throwing was something about it not starting? Sorry we took it to the dealdr last year for this so I am not sure.
MS3: Will do what ya said. I was beginning to suspect the ignition switch when this last time the infotainment system never shut down like the rest of the bike did.
Rax
Rax
