front brake
front brake
15 tri and after my bike sits overnight the front brake lever goes all the way tp the bars. done this since new. anyone else ever have this ? i'm thinking it just needs the front brake bleed alitte. the rear pedel does not do this, so i'm thinking just break the bleeders loose for the front. maybe it's suppose to be this way with the linked brakes ? never had a bike with it before. i grew up on bikes that didn't even have front brakes. gotta get a handle on this new crap.
Yeah, I agree. Brakes are too important. Your bike should still be under warranty. Let a competent dealer check it out.
You have air in the lines. Get yourself a good vacuum pump and bleed those front brake lines. I would also suggest using a helper to make sure to keep the reservior full when bleeding.]
Also a safe method for adding brake fluid is to use a plastic bag wrapped around the front reservior, to prevent any spills.
Hope this help.
Hope this help.
