Failure to sync
Phone is not syncing. Make sure your phone is paired to the system. If you have the latest up date the Bluetooth has to be turned on every time you start the engine. Once the system is up and running you will not see the Bluetooth symbol on the bottom.
Home screen click set up
Scroll down to Bluetooth turn it on.
Sadly this will have to be done every time you boot the system up. For some reason Bluetooth shuts off when bike is shut off. This does not happen with every one.
Never had a problem until the last two updates. Took a while to figure it out with help from this forum, but betting that is the problem.
