Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Reverse Motor
Old 05-28-2016, 04:48 PM
Vince2272's Avatar
Vince2272
Vince2272 is offline
Default Reverse Motor
Hello
Does anyone know what solenoid HD uses on their reverse motors?
Can't shell out $1,400.00 for a new motor when all I need is a solenoid.
Thanks
Old 05-31-2016, 07:37 AM
Gitarded's Avatar
Gitarded
Gitarded is offline
Are you talking about the drive gear solenoid or the motor solenoid? If for the drive gear you might be better off to take it to a starter motor shop.
Old 05-31-2016, 04:52 PM
Fusionfool's Avatar
Fusionfool
Fusionfool is offline
Before I would pay $1400 I will go this way.
http://www.motortrike.com/TrikeReverse.aspx
Mechanical motor driven reverse, about the same price but will last much longer.
Sorry I do not know the answer to your question for solenoid.
Old 06-05-2016, 12:15 PM
sprinkman's Avatar
sprinkman
sprinkman is offline
If you want a to rebuild it check with. www.performancestarter.com
I think they rebuild them for around 300.00 1 year warranty.
Old 06-09-2016, 09:44 AM
rhino 2's Avatar
rhino 2
rhino 2 is offline
Originally Posted by Vince2272
Hello
Thanks
I had my reverse motor out 3 or 4 times Cleaned the bushes sanded the commutator myself .. And worked for a short time.. After doing that twice i took it to a rebuilder he rebuild it while i waited [95dollars] That worked for a little over a year.. So i bit the bullet and put in a Moto-trike mechanical reverse in.. Shouda did that the first time.....
Bye the way the Harley's reverse is made by Hitachi ..
Old 06-09-2016, 04:12 PM
Clint44's Avatar
Clint44
Clint44 is offline
Champion sells a mechanical reverse kit,too. We have one on our trike.
JimmyT1950
17
08-06-2013 03:35 PM
ttikalsky
Shovelhead
03-11-2010 07:58 PM
jfm5
09-06-2008 11:31 AM
jfm5
07-21-2008 01:23 PM
shenork
04-16-2008 05:26 PM
Quick Reply: Reverse Motor
