Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
2016 Tri-Glide Windshield Pouch
Old 07-08-2016, 10:50 AM
bagger51's Avatar
bagger51
bagger51 is offline
Default 2016 Tri-Glide Windshield Pouch
Anyone mounted a windshield pouch on 2016 Tri-Glide? It has a vent on the upper fairing that can be opened or closed. It seems like the pouches would interfere with it. Maybe a windshield pouch without a middle pouch?
Old 07-08-2016, 11:15 AM
rhino 2's Avatar
rhino 2
rhino 2 is offline
Harley, Has one for the newer vented windshield's....
Old 07-08-2016, 02:05 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
have it on mine, it does change the airflow ever so slightly,imo not near enough to go without.
Old 07-09-2016, 02:36 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Oogie Wa Wa is offline
The Harley one does seem to lower the amount of flow, or at least re-direct it for me. I don't feel a whole lot of change with it open or closed, but it does make some difference. The bottom is tapered up away from the windshield instead of flat like the old ones to give the air a path. Still room for the garage door opener, phone and fob in the middle, flashlight, USB adapter and cable for phone charging, a couple of other little things in there. Not waterproof.
The last time I had the outer fairing off, I pulled up on the pouch after loosening the screws a bit, I got it to raise up maybe 1/8" or so from when it just sat on the screw lugs. If you'd want to raise it another say 1/4", you could easily do some creative trimming of the bottom where the screw holes are for a little more air flow. I'm considering doing that some time.
Old 07-09-2016, 05:47 PM
IllinoisCheesehead's Avatar
IllinoisCheesehead
IllinoisCheesehead is offline
I put one on and took it back a week later. As others said, it's supposedly designed to work with the Rushmore fairing vent, but for me it obstructed the flow so that there was little difference between the vent open or vent closed. I prefer the vent open, and with the pouch on, it was as if the vent was always closed and it made for a more turbulent ride. I decided I could live with putting my phone in the tour pack and my keys in my pocket so that the vent can work the way it's supposed to.
By the way, if you do try one, ignore the instructions. You don't need to use different bolts, pull the fairing, put on the gaskets, etc. I put mine on in the HD dealer parking lot in 5 minutes using nothing but the hex key from the multi-tool that came with the trike.
Old 07-10-2016, 05:56 PM
bigdumbnoitall00
hey cheese head u got my trike, except mines a 15 limited.
EasternSP
2014-2023 Touring Models
17
09-30-2017 04:02 PM
Roadrunner14
16
09-16-2011 03:07 PM
bluebagger
03-25-2009 04:06 PM
kc10boom
09-30-2008 09:06 PM
AZFLHX
06-06-2007 11:14 AM
Quick Reply: 2016 Tri-Glide Windshield Pouch
