Parking brake???
..I have had my 09 for seven years now !!!!....the only shortcoming with this thing is the parking brake....I have adjusted it three times....does not last long......SO.......about two or three years ago...I removed the entire system........don't have to adjust it if it aint there.....one thing to remember....before we had three wheeler motorcycles....we had no parking brakes...........but I do remember the servicars from the sixties had a good parking brake on the right handlebar.......anybody remember that.....
Bikes can't roll.. If they do fall off the kick/sissy stand they will drop right there ' and sometimes on the riders leg... Three wheelers will just roll away into the sunset till they hit an unmovable object...
It isn't very hard to remove the pieces and parts, I can't speak for the inspection since my state has none for bikes and trikes.
When I stopped taking Big Blue to HD for service and started doing it myself, I was amazed that only the right side (closest to the handle) caliper bolt for the e-brake was adjusted anywhere close to the back side of the caliper. Left side was waaaay out compared to the right. Since adjusting both sides by the shop manual, it works fine. As for premature pad wear, that's another story. Like someone else mentioned, I've had mine roll a few feet in first gear too. I didn't like that a bit. Luckily, it's flatter than Kansas here in the San Joaquin Valley.
My 2016 works properly when the f*^"=%g return spring is there. At delivery I was told and demonstrated a few times how to engage and disengage the parking brake, dash light and all. Sales associate showed me to step on it to engage, click, click. Then he insisted that if I don't abruptly disengage, the brake would still be on, light on dash on bike won't move. However when you slide your foot off the brake pedal like dumping the clutch it disengages fine. I learned how to do it before I got out of the dealership when I engaged it and forgot! Return spring quit working and was replaced under warranty and second one is gone now. I guess I am going to have to figure out a way to keep it in there. Mine works when its all there.
