What's that damn squeak?
It probably wouldn't hurt any to go around and snug up the fasteners on the fairing, windshield and anything else you can find up front.
Squeaks are funny, two things are rubbing against each other; they are held together enough to keep them in contact, but not enough to keep them from moving. I suppose the only good news is that soon after they stop squeaking, the fastener is loose enough that now they rattle, but no more squeak!!!
Edit: The other answer is that your radio just isn't up loud enough, of course...
Squeaks, like rattles can drive anyone nuts!
On my 2000 Ultra, I had the rubber muffler hangers that need an occasional squirt of silicone spray.
The other squeak (harder to locate) was the exhaust clamp/hanger over the transmission. I finally gave up and bought a new clamp and the issue was settled.
On my '13 CVO Ultra, I have a squeak in/around the upper fairing windshield.
While driving (and hearing the squeak) I could put a little pressure on the top of the windshield and the squeak would stop.
I pulled the windshield and put a long piece of duct tape across the bottom of both sides of the windshield and I still had the squeak!
I kept searching (while riding the bike) and finally located the culprit!
Two pieces of trim that I had added to cover the face of the radio and to cover the rocker switches near the ignition switch were too close together and were making contact.
Two of my favorite tools for searching for squeaks and rattles are a rubber mallet and a short piece of rubber hose.
One to pound with and the other used as a stethoscope.
I started a thread on 09/08/2015 entitled "Squeak". The short story is that I searched for a long time for that squeak. I finally found it when I released the last body to frame mounting bolt in the trunk. I think that the body got rim racked a little bit at some point, maybe when I hit a bump, and when I released that last bolt, everything went back to where it wanted to be. I haven't heard the squeak since then.
