starting in gear
you can start them in gear if you pull the clutch in and apply the brakes. that's the only way it will start in gear. the part about stepping on the brakes is what i don't like. i was moving and had to put the brakes on in order to get the thing started to keep from getting run down. hd protecting oursleves from oursleves ? this feature will get you killed.
does anyone else find it a pain in the *** or even dangerous when you have to step on the brake to start your bike in gear ? my bike died going though an intersection and i was in second gear and it just died( don't know why, but it did). i was moving and pulled the clutch in and hit the button, nothing ,had to hit the brakes to get it started which slowed eveyone down. a guy could get runover having to fool with this sillyness. my question is , is there a way of getting around this on these trikes ? don't like it and don't want it like this. THANKS ALL !
I agree, this is a safety hazard. Have a 2020 Tri Glide Ultra and have to either have it in Neutral or apply the brakes and the clutch to start in gear. This is dangerous in any situation if it stalls in an intersection. I contacted Harley Davidson and was told "it is designed that way and working as it is supposed to. When I told him this was a dangerous design flaw, he said he would forward my complaint, but that most likely nothing would be done about it.
My next phone call was to the NHTSA Vehicle Safety at (888) 327-4236 and recommend you all do the same. Based on my discussion with the gentleman that I talked with, he agreed that this is a safety issue and that it would merit an investigation if there are enough complaints.
GrampT (05-21-2021)
I agree it is a blunder on MOCO's part, but they haven't changed it. Also how many accidents has it caused. If it hasn't caused any accidents there isn't much to stand on other than something could happen. What they will counter with is the safety factor of running into something if you start in gear without the brake applied. Which has happened.
If someone has caused an accident, sure they do need to contribute to the knowledge base.
Casper (05-30-2021)
As has been discussed on these forums multi times,,, Pull in the clutch and depress the brake slightly. Just enough to turn on the brake light and hit the start. The motion doesn't have to stop. I don't think it makes a difference which brake you use. I could be wrong on that. But you don't have to find neutral.
My point is that it should be set up the same as any of the 2 wheelers. If it's in gear, you have to pull the clutch to engage the starter and if it's in neutral, then you just have to push the starter. I don't have to apply the brakes on any of my 2 wheelers to get them to start.
